matthewb1985
Throttle body cleaning
What is the bes way to clean the throttle body and is it worth replacing the throttle switch while its off.
Also how do i go about porting and polishing, using counter sunk screws etc?
any advice appreciated
Mmm, I've got a spare VR throttle body and also want to know where to port and polish it. If anyone has a "before" and "after" pic with the relevant areas marked that would be a help. As is, i cant see where anything would need to be machined.
carb cleaner or thinners
i ported mine out with a dremel....just smooth and remove anything that looks in the way... i also slimmed down the spindles and screw heads
:offtopic1: [OT]Do 2.0L 16v TB's have a throttle position sensor on them? [/OT]
