leemeg99
VR6 AUTO GEARBOX DRIVING STYLES
THE CORRADO VR6 I OWN, 1994
CHANGES AT 4000 REVS, INTO 1,2,3,4
DOESN'T CHANGE UP BELOW THIS, IS IT NORMAL ?
DO THE ELECTRONICS REMEMBER PREVIOUS OWNERS DRIVING STYLE AND ADOPT THIS, IF SO HOW CAN I RESET THE MECHANISMS
THE CAR ONLY SEEMS TO RETURN 22MPG IS THIS RIGHT?
MANY THANKS
LEEMEG99
pardon???
:D
sorry yer caps lock is on which is the equivilent of shouting
anyway the G/box ECU from memory doesn't have a memory function such as remembering differing driving styles by different ppl............its possibly just needing a new sensor or more simply a change in autobox fluid
You can reset the auto box by the following:
ignition on engine off
press the accelerator to the floor and hold for 10 seconds
release accelerator and start engine directly. Do not turn off before starting.
That will reset teh box. It adapts to your driving style so you will need to go through a brief setup using different gear changes.
blimey you learn something new every day................i was always under the impression it wasn't "adaptive" and just a conventional slushbox
22mpg around TOWN for an auto vr6 would be pretty darn good to be honest. Most manuals won't do that round town.
The autos are thirsty as fek!
double-6s, i get about 23-24 on mine, around town, but then the MFA is prob about a few MPG too high anyway.
