flusted
Just fitted an Charge air temp gauge to my g60
Just fitted a charge air temp gauge.
Checked outside temp and it was approx 20deg,then whilst driving at approx 40mph i was seeing approx 23degrees?
Guess that means the front mount intercooler is working well?
Did notice sat at a junction,it did creep up to 27degrees,but as soon as i started moving it just drops right down to 23ish.
I tried flooring it aswell and it stays about the same!
What do you reckon?
where did you mount yours? And how did you mount the sensor in the airflow - pics would be good as I have to do mine!
I just took out 1 of the blanks and it fits perfect in there.
Then i filed a slit in my co pot,ran the wires down the slit and then insulation taped it round.
Difference is, i have my co pot pushed in a samco dumpvalve outlet!
Il go and take pics now
thats the kit i have! although i am not sure if i have any room on my dash, as i already have a air/fuel gauge in there! i am sure i will figure something out! cheers for the piccies flusted!
that's the same kit I've got too... 8) (although mine's a reversed LCD 'cos I'm a bit like that! :lol: )
how did you wire it in? i am yet to recieve any instructions yet.... where did you wire in the blue and white wires??
Nice one! IC defo doing it's job and only 3 degrees above ambient is bloody good going!
I might tap in a second VR6 IAT sender and do the same thing, nice idea 8)
All mine had was positive and negative
Yeah my ebay kit came with a blue and white wire, which i am guessing is positive and negative...
Whereabout did you wire you positive and negative wires into?
ran the live from the ignition,and spliced into an earth i have for boot switch.
I want another 1 now to see ambient rather than the mfa 1
wow that is good going. i run a charge cooler and on the motor way cruising its 10'c above ambient. sitting in traffic it can get to 15'c. proves it really. fmic is THE way to go.
oh but when the water inj kicks in it drops to about 10'c below ambient..
i put my sensor straight into the throttle body. its been in there about 3 years.
what i/c are you using. rallye / golf or a made up one.?
is that one of the ones off ebay. the core is it 600x300x76.? only i had one but sold it. cos i couldn't see it fitting. but you are usin the rs bumper...
bit of a squeeees. did you use a rallye elbow.?
Yeah of ebay as Giant intercooler for drag use! I had to have the end caps modded,then used a samco right angle reducer to come from charger to ic
