Twiss 0 Posted September 20, 2006 Well I got thinking which can be bad for me will a vr6 gearbox fit a 1.8 16v engine ? if so what would be needed to fit it ? Except a v6 engine I know a standard valver would have no benefit whith the v6 gearbox fitted but would it a make a differnace if the valver has turbo fitted? I'm sorry if this question has already been asked, I'm still searching through search results. Thanks Quote Share this post Link to post Share on other sites
Henny 0 Posted September 20, 2006 VR6 gearbox has a completely different bell housing from the 4 cylinder gearbox... You'd need to change the bell housing over to get it to fit, and even then I'm not sure if it'd work or not... Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 20, 2006 Well I got thinking which can be bad for me will a vr6 gearbox fit a 1.8 16v engine ? if so what would be needed to fit it ? Except a v6 engine I know a standard valver would have no benefit whith the v6 gearbox fitted but would it a make a differnace if the valver has turbo fitted? I'm sorry if this question has already been asked, I'm still searching through search results. Thanks the 1.8 16v gearbox has closer and shorter ratio's than the other Corrado boxes, it's actually the best suited to the high revving valver. Quote Share this post Link to post Share on other sites
Twiss 0 Posted September 20, 2006 oh Right so how high does the v6 rev then ? Does anyone know what the max speed you would get from a standerd box with lets say a supercharged or turbo valver? Would a sports clutch benfit the valver ? if so what do you recommend? Quote Share this post Link to post Share on other sites
eatthis 0 Posted September 21, 2006 6200 for golf vr6 im not sure but i think rado is 6500 Quote Share this post Link to post Share on other sites
Twiss 0 Posted September 22, 2006 is that when it start to redline ? I thought it would be much higher for the vr6 Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 22, 2006 6200 for golf vr6 im not sure but i think rado is 6500 7200 on the 1.8 valver. 7000rpm would get you to about 150mph on the 1.8 5th ratio Quote Share this post Link to post Share on other sites
