balboa
where is the idle stabilisation valve???
It's at the back/top of the engine under the rear black plastic part of the engine cover. Has a couple of black rubber hoses running to it.
what about a 16v? think mine needs changing
as you look at the engine, on the right hand side, there is a mini coke can sized thing with 2 pipes going to it, there is a plug on one end too. thats it.
Not necessarily needs changing only cleaning.... i cleaned mine as my idle was running high bout 1250rpm then cleaned it and idle purrrfect bout 750. need to do it again though bout 5 months and 5000 miles down the road :monkey: :bad-words: maybe it needs replaced but at i think it is an expensive part to replace
