pkripper 0 Posted September 29, 2006 Greetings everyone, My G60 has a fault in that the lights on the dash come on when you try to start it but it doesnt turn over, a bit like when the iginition switch has gone. I am going to check the earths tomorrow, is there anything else off hand that I should check as well? All help much appreciated. Thanks Matt Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 29, 2006 get a cheap multimeter..test that the battery has 12v+ and then test whats at the starter while a helper cranks it over Quote Share this post Link to post Share on other sites
pkripper 0 Posted September 29, 2006 get a cheap multimeter..test that the battery has 12v+ and then test whats at the starter while a helper cranks it over I will try that, I just get the clicking when I turn it over though. What is the next point of call if there is no voltage getting to the starter? Quote Share this post Link to post Share on other sites
Toad 0 Posted September 29, 2006 Does the starter click? Quote Share this post Link to post Share on other sites
pkripper 0 Posted September 29, 2006 Does the starter click? Not sure if it is the starter clicking, its got a brand new on one though. Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 29, 2006 when it clicks next....i suggest you turn the ign on and see if main beam is as bright as expected , that should confirm if the battery has enough juice to attempt to start the car if there no voltage at the starter...but the battery is good, then its probably a battery lead Quote Share this post Link to post Share on other sites
pkripper 0 Posted September 29, 2006 when it clicks next....i suggest you turn the ign on and see if main beam is as bright as expected , that should confirm if the battery has enough juice to attempt to start the car if there no voltage at the starter...but the battery is good, then its probably a battery lead Thanks Steve. Maybe i should change those leads on the alternator as well we talked about at Bluewater? Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 29, 2006 yeah the factory leads arnet very thick....doesnt cost alot if you can do it yourself Quote Share this post Link to post Share on other sites
pkripper 0 Posted September 30, 2006 Got it going and have changed the battery terminal again. When you turn the key the dash lights still come on and nothing happens, but there is a knack where if you hold the key on full turn and turn it, it will then fire up. I have replaced the ignition switch and there is power to the starter motor. Also, it will sometimes just start with no problem. Anyone got any further ideas? Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 30, 2006 any imobiliser still on there? Quote Share this post Link to post Share on other sites
pkripper 0 Posted September 30, 2006 any imobiliser still on there? Yes, cat 1. Quote Share this post Link to post Share on other sites
steveo29 0 Posted September 30, 2006 i would suggest you bypass it for a while to see if the fault is still there Quote Share this post Link to post Share on other sites
pkripper 0 Posted September 30, 2006 i would suggest you bypass it for a while to see if the fault is still there I will try that. Quote Share this post Link to post Share on other sites
