gollfy
8V Brake disc size?
I have a standard 1995 2.0 8v rado and just need to know the size of the brake discs that fit it:) are they 280mm?
Thanks all
Er, should be 256mm.
yep 256 as standard, you could always measure yours :wink:
only confusion with a motor factors might be that the 2L 8v engine was used on the mk3 golf and that had 280mm brakes (but 5 stud).
AFAIK the only vws with 4 stud 280's were the G60 corrado, rare G60 golf and even rarer G60 passats.
