easypops
high idle
hi all, my 2.0 16v seems to have the same thing as a lot of others.
i know this subject has been covered many times but i havent seen the exact same symptoms as mine(apologies if there is and i missed it)
the car starts first time all the time , idles a wee bit high for a couple of secs then settles about 9
the car will run fine then but when switched off and then re-started the idle problem starts, generally quite high and a bit up and down
recently cleaned the isv with carb cleaner, soaked in petrol and oiled before re-fitting. this seemed to help but the problem has gradually returned
the car has a newish distributor, newish leads and a recently replaced throttle body.
if anyone has any thoughts that would be great
cheers martin
Does this engine use a fuel pressure regulator?
What about the vaccum hose up to the ECU?
Is there also an idle bolt on the throttle body along with micro-switches?
Keep posting! :)
got it sorted mate, its on another thread but i dont know how to put a link on here.
its explained there, found the problem by luck more than anything else :D
