Tristan
Charger problem
Hi there.
I have a small charger problem..if I can say so :) What do you think will it make some boost? There's a pic below with it.. I will have a 68mm pulley,RSR outlet and light ported charger (DIY job)
Someone tried to repair the side wall were the apex strip are... it doesen't worked well... he burned it :( Now I hope it will make some boost until spring when I want to swap it for a turbo... hope I'll bump into one piece of K04 or something similar :)
What kind of tdi exhaust manifold can I use for the turbo? I mean from which engine (1.6, 1.9?) passat, golf? and what year?
