rado
gearbox
hi can anyone tell me are the mk 2 gti g boxs same as the corrado 16 valve box any help appreciated
1st gear ratio,s different on corrado due to the car being 400lb heavier...golf 16v and scirocco 16v 1st gear ratios are ... 3.45:1 , while corrado ratio is ...3.40:1............ hope this is of some help, i got the info from { vw power and style by ian kuah
They are both 4 cylinder bell housing 02A series but as DiTch says, the ratios are different.
Corrado is cable change 02A, golf 2 is rod change 020 you'll need a complete cable change setup to use a C box in a mk2 16v. Oh and the starter is different. I've never heard of anyone retro-fitting a rod change box and selector in a corrado and an 8v golf box would have way out ratios for a corrado 16v.
1.8 16v corrados have lower ratios than the 2L 16v's and I'm not sure those ratio's above are right either, the data sheet I have reckons all the 4cyl C's have the same ratio 1st, it's the final drives that are different along with some of the other gears (1st is 3.778) (vr6 is 3.3)
