mattkh
Heater flap
Hi
Anyone got a picture of the flap in the heater that moves when you slide the hot and cold lever.
Cheers. :)
apparently the water circulates in the matrix regardless of the lever being on hot or cold. so this flap controls the heat to the car. how does it do it? A picture will be a great help.
Hi Matt,
The attached pic shows the heater box, the highlighted bit shows where the hot/cold air flap sits.
Hope it helps
Dan
Nice one!
I´ve been thinking about this for some time.
Why?
Because when i place the lever on a hot position, the next day i have the floor wet! :!:
So i´m always running the lever on the coldest position to avoid this. :wink:
The weather is getting colder, and i´m freezing aswell.
Is there any explanation for this issue? :roll:
Hey Kongo,
The explination is your heater matrix is leaking....
Its a bitch to change but use the search there is a really good guide to fitting a new one without removing the dash!
best of luck
Dan
