Dub_nut_g60 0 Posted November 29, 2006 Time to call in a favour!! my ABS light came on when i was on my way home tonight. Got home to find that my drivers side rear brake has seized on. Is there by chance anyone in the Portsmouth area who would be able to come round give me a hand? really need it sorted saturday for the drive up to Stealth sunday!! If not it will have to be a trip to Kwik Fit, but would rather avoid if i can!! Thanks in advance Andy Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 29, 2006 There's no real fix apart from new caliper dude... Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted November 29, 2006 Will GSF do for it? And in that case, could anyone give a hand fitting saturday if i can get one?? (im ok with a spanner, but not confident enough to mess around with things like brakes!) Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted November 30, 2006 have ordered the part form GSF - £54 plus vat! but a £30 surcharge on the old caliper, so not so bad! Question, does anyone have a guide for changing the calipers? I take that when i take the caliper off it will effectively drain the brake fluid, so i will need to refill with Dot 5.1 (right?) and bleed them - probabaly stupid question, but how? Cheers Quote Share this post Link to post Share on other sites
Goldie 2 Posted November 30, 2006 If there are flexi hoses on the calipers you should be able to clamp them to reduce any spillages. Front ones are a doddle but the rear brake arent my forte or id have a run over from gosport and give you a hand. Dont imagine theyll need to be fully bled. Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted November 30, 2006 Goldie said: If there are flexi hoses on the calipers you should be able to clamp them to reduce any spillages. Front ones are a doddle but the rear brake arent my forte or id have a run over from gosport and give you a hand. Dont imagine theyll need to be fully bled. Ah cheers! Feel free to pop over (i also need to get to GSF to get the new caliper!!) as some help will be better than no help! also if its not sorted saturday then there wil be no bbq sunday...... Quote Share this post Link to post Share on other sites
Goldie 2 Posted November 30, 2006 Where is GSF in Pompey?? Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted November 30, 2006 Postcode is PO3 6FH, just off the Eastern Road by the looks of it, just to be in Paulsgrove opposite king Richards School but moved recently. Quote Share this post Link to post Share on other sites
Goldie 2 Posted November 30, 2006 Ill give you a lift to get the caliper if you need. Ill give the guy a phone who changed mine not long ago and get some advice once ive finished work ( i have a feeling he might be on holiday but iil try). Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted November 30, 2006 That would be superb mate! Ill drop you a PM later. Quote Share this post Link to post Share on other sites
Goldie 2 Posted November 30, 2006 Missed the closing time of the garage so ill try tomorrow. Drop me a line of where you live and we will sort something out for saturday morning. Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted December 1, 2006 Cheers buddy, just sent you a PM. Quote Share this post Link to post Share on other sites
Toad 0 Posted December 1, 2006 I think there's a proper method for bleeding the brakes with ABS.... Haven't a clue what it is though..... Remember to get some copper grease for the backs of the brake pads... Quote Share this post Link to post Share on other sites
Toad 0 Posted December 1, 2006 Oooh pick up the relavent Passat Haynes manual, and it'll probably tell you... Just thought of that... Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted December 1, 2006 Toad said: I think there's a proper method for bleeding the brakes with ABS.... Haven't a clue what it is though..... Remember to get some copper grease for the backs of the brake pads... Good thought! will do! Quote Share this post Link to post Share on other sites
Shaggy 0 Posted December 1, 2006 Andy if you get majorly stuck i could always pop round and help mate? I gotta fix my Gfs polo tm so if i get that done i may be able to pop up and help??? Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted December 1, 2006 You have PM! thinking the more help the better! Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted December 2, 2006 Just taken the wheel off, tried to spin the disc, and the whole thing wobbles! have checked with GSF and they have them on the shelf. Anyone think of anything else i need? Have caliper and bearing at GSF, have a disk in the garage so will probabaly put that on while im/were at it! Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted December 2, 2006 Any thoughts as to where i can get a bearing pressed in on a saturday afternoon? And any idea about getting the caliper off??? bolts are stuck like a good un! Quote Share this post Link to post Share on other sites
Toad 0 Posted December 2, 2006 You can press the bearings in with a large socket and a vice.... You might need to heat the caliper bolts with oxy acetylene. or try worth rust off... it's a freezing spray. If the bolts look like they'll round off, use a six sided socket, rather than a multi spline. If I was closer i'd give you a hand myself. Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 2, 2006 They all back on now Dub_nut_g60??? Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted December 2, 2006 Nope!!! a race is stuck on the stub axle! Toad is on his way round with a spare stub! Will be there tomorrow though!!! Quote Share this post Link to post Share on other sites
Shaggy 0 Posted December 2, 2006 Your cutting it very fine andy! still i am sure you will make it! :D sorry i couldnt help today the polo took ages to fix...i have just sat down :roll: Quote Share this post Link to post Share on other sites
Dub_nut_g60 0 Posted December 2, 2006 No worries mate!!! As long as it doesnt play up on the way there tomorrow ill be a happy boy!! A huge thanks to Goldie for his help and letting me take his Storm for a spin Quote Share this post Link to post Share on other sites
Goldie 2 Posted December 2, 2006 Your welcome mate, hoping to loose my G60 virginity tomorrow. Hope it gets sorted. Ill phone when im on the way to tescos in the morning. Quote Share this post Link to post Share on other sites
