camper driver 0 Posted December 17, 2006 Number 5 injector is open constantly and pouring too much petrol into the cylinder. The injector is Ok. They appear to work with a constant 12volt supply and a switched earth (presumably through the ecu) all other injectors are around 60 ohms to earth with ignition on but number 5 injector is around 6 ohms. all are infinate when ignition is off, suggesting its not a wiring fault. Is this my ecu? can they be repaired? If not where can i buy one and how much are they? Quote Share this post Link to post Share on other sites
easypops 8 Posted December 17, 2006 is that the blue one? if so mine hasn't been active for at least the last year. its the cold start thing.... on my 2.0 16v anyway... mine has the plug disconnected and the car runs fine without it Quote Share this post Link to post Share on other sites
VR6 0 Posted December 17, 2006 Other two threads deleted. Quote Share this post Link to post Share on other sites
Toad 0 Posted December 17, 2006 is that the blue one? if so mine hasn't been active for at least the last year. its the cold start thing.... on my 2.0 16v anyway... mine has the plug disconnected and the car runs fine without it Think it's for a VR6. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 17, 2006 Yeah - sounds like a VR so it's sequential injection... have you swapped it with another cyl? Quote Share this post Link to post Share on other sites
