Slimg60 0 Posted December 31, 2006 Found my downpipes blowing today just below the join to the manifold. Will 16V ones fit? Cheers. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted December 31, 2006 I dont think they will! Quote Share this post Link to post Share on other sites
Slimg60 0 Posted December 31, 2006 So does it have to be a specific G60 set? or will 8v golf fit? Quote Share this post Link to post Share on other sites
Crasher 3 Posted December 31, 2006 The 8 and 16v down pipe will both fit but the 8v is 5-mm smaller so the system won't fit without an adapter and neither have the location for a lambda sensor. I use a G60 down-pipe on 2L 8v G2 conversions so I can run a cat bypass for a lambda sensor fitting (piggy back or aftermarket EMS) then into a 16v G2 system. Quote Share this post Link to post Share on other sites
flusted 0 Posted December 31, 2006 was guna say the 1.8 16v doesnt have lambda so would need to be 2l 16v downpipe Quote Share this post Link to post Share on other sites
Crasher 3 Posted January 1, 2007 Yes the 9A downpipe would fit but is still technically a different part to the G60 part. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted January 1, 2007 9A 2.0 valver downpipe def. fits to G60 8v ex. mani.,i had to fit 1 when i had the 16v-G60 engine in. Quote Share this post Link to post Share on other sites
Slimg60 0 Posted January 1, 2007 So a 2l 16v one will fit? Just as well as the hole is now huge and the MOT is approaching fast. Quote Share this post Link to post Share on other sites
Crasher 3 Posted January 1, 2007 Yes, a 9A 2L 16v one, 358 253 087. One from an ABF 2L 16v G3 may prove to be awkward as it is designed for a tall block. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted January 2, 2007 Sorry if OT but is you crasher from Preformance golf magazine?,i used to sometimes be able to locate that mag here in Rome and,if i'm not mistaken,you used to write 'Crashers corner'??,exellent write-ups with good tech. info. I don't suppose you have any old mags you wanna get rid of?... Quote Share this post Link to post Share on other sites
Slimg60 0 Posted January 2, 2007 Thanks for the help guys, managed to get hold of the correct pipes, should arrive tomorrow. then the task of fitting them. :? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted January 2, 2007 The only tricky bit are those bloody 17mm nuts holding it on to the ex. mani.,grab a long extension and 2 universal joints and you should be ok,check the gasket's intact aswell and put some copperease on the threads before re-fitting. Quote Share this post Link to post Share on other sites
