Craig
probably a silly question but...
if i remove the top radiator hose to put a new shiny clip on, it wont create an air block or something will it in the cooling system? had cooling issues few months back and dont want to upset anything, am i being too stupid :roll:
cheers, thought it would be ok but to save any hassle thought id just check first.
If you loose a bit of coolant, just make sure you check the level in the header tank after the engine has cooled down after your first few journeys, sometimes trapped air can take a little while to work through the system, just top up as needed.
