belfastfumanchu 0 Posted January 17, 2007 Can someone tell me how the fuel injectors are supposed to sit in the 1.8 16v. Are they meant to sit slackish in the engine and should you be able to just pull them out and push them back in without any tightening? Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 17, 2007 sounds like you need new o rings...they do pull out , but it takes a good yank usualy , they should be fairly firm and not rattle about Quote Share this post Link to post Share on other sites
belfastfumanchu 0 Posted January 17, 2007 I see, any idea how much o-rings are steveo ? Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 17, 2007 not much at all mate.. Quote Share this post Link to post Share on other sites
flusted 0 Posted January 18, 2007 Best to tap injector back on with a mallet and screwdriver to ensure they are in nice and tight Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 18, 2007 ^^^^^then it smashes the plastic insert Quote Share this post Link to post Share on other sites
flusted 0 Posted January 18, 2007 16vs use metal inserts Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 19, 2007 16vs use metal inserts all the ones ive had apart have plastic ones with a screw in brass top....if you bang the inj in you will break the plastic bits, theyre mega brittle anyway they push in simply by hand...no need for a mallet Quote Share this post Link to post Share on other sites
