sparkz 0 Posted January 17, 2007 As above guys. I am now running a 2.9 bottom end as i had my 2.8 block rebored with forged pistons to 2.9 spec. I bought a metal head gasket for a 2.8 but as the bore size is now slightly larger, will i need to change the head gasket (i think i will :roll: ) to 2.9 spec? Is there a company that make an o.e head gasket in metal. I dont really want to go for a spacer gasket as the comp has been lowered already due to the forged pistons. Cheers in advance! Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 17, 2007 Just get the MK4 VR6 head gasket mate,its a three layer metal gasket,it fits the 2.9 with no problems. Quote Share this post Link to post Share on other sites
sparkz 0 Posted January 17, 2007 Cheers mate! How's your turbo route going? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 17, 2007 Just waiting for ATP to send most of my bits then its just a matter of bolting the bits on,then i can start to play!! By the way the part number for the metal HG is 021 103 383N What Turbo and manifold you running sparkz? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 18, 2007 That's a good point, do the cylinder rings in the gasket mate right up the cylinder walls or is there a gap? I guess they don't, but I've gone from 82mm bore to 83.5mm and that wasn't flagged up when Stealth built it, so I guess one gasket fits all :-) I think Sparkz likes his midrange torque like me, so won't be going for a massive turbo! Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted January 18, 2007 83.5mm bore, is that right? Thought 82.5mm gives 3.0L and 83.0mm gives 3.1L? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 18, 2007 Aye, 83.5mm bore gives 2967cc. 82mm gives 2861cc 82.5mm gives 2897cc 83mm gives 2920cc or something, haven't worked that one out yet. it's crank stroke that gives 3.1 Quote Share this post Link to post Share on other sites
VR6Will 0 Posted January 18, 2007 I think Sparkz likes his midrange torque like me, so won't be going for a massive turbo! i believe he's going for a gt35r Quote Share this post Link to post Share on other sites
JIMMI 0 Posted January 18, 2007 Girl, whats wrong with a T70 ????????? Ha Ha ! Jimmi.............. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 18, 2007 :lol: T70 is for men only, LOL! I like my girly GT30 :-) 35R is a lovely turbo. With a .63 turbine AR it will spool like a GT3071..... nice 8) Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted January 18, 2007 Gotcha, so my 82.5mm is only abit closer to 2.9L then. :( Sounds wicked what you're doing with yours, when are you going to try super and turbo charging together? :) Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 18, 2007 Yeah yours is a true 2.9 now, instead of a 2.8 and a half :-) Cheers! Yeah I thought about compound charging and I reckon an electromagnetic air-con pulley system could work to decouple the supercharger at a specific rpm, but maintaining Alternator, water and PAS drive. Then the turbo takes over 8) An rpm signal from a schrick controller would manage that easily :-) As for supercharger choice, it would need to be a Rotrex as the Vortechs don't deliver enough low end boost to make it worthwhile. Ideally you'd want 3 or 4 psi right from idle, rising to 10 or so by 3500rpm and then cutout. The downsides are turbos are throttle position, load AND rpm sensitive, so it might interfere with the charger when not needed. And when the super engages and disengages, you'll get a quite a shunt through the drive train. And the pipework, intercooling and mapping would be fun! I bet VW's 1.4 twin charger is much more complicated than it looks! Quote Share this post Link to post Share on other sites
sparkz 0 Posted January 18, 2007 I think Sparkz likes his midrange torque like me, so won't be going for a massive turbo! i believe he's going for a gt35r Yep, gt35r it is! Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 18, 2007 Ditto,but with .82 exh AR. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted January 18, 2007 Be aware that the Mk4 headgasket will bump your compression up, from 10:1 to 10.5:1. Quote Share this post Link to post Share on other sites
jonrb 0 Posted January 20, 2007 Be aware that the Mk4 headgasket will bump your compression up, from 10:1 to 10.5:1. Indeed. In fact, for NA installs that's an advantage. Vince has just offered me a thinner metal gasket as a NA tuning option because it raises the CR. Has anyone else done this and able to comment on it? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 20, 2007 It does raise the CR but it hardly makes any difference at all.Not worth it IMO Quote Share this post Link to post Share on other sites
jonrb 0 Posted January 20, 2007 The head is going to be off anyway and the gasket is going to be changed anyway, so it's more a case of "why not?" than anything. The only downside is that I'll need to run on Super-Unleaded whereas for the past 10 years the car has run on nothing but standard 95RON. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 20, 2007 why only super? Quote Share this post Link to post Share on other sites
jonrb 0 Posted January 20, 2007 why only super? I dunno. That's just what Vince told me. Maybe the slightly higher CR makes it more prone to pinking? Or maybe the only way to take advantage of the slightly higher CR is to map the car to need SUL otherwise there is no gain? I suspect the latter. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted January 20, 2007 I cant see .5 of a Cr increase needs super,that's just crazy,its not worth the raise in fuel costs for a steel gasket that hardly makes a difference,anyway my mates VR runs unleaded all day long with no difference in performance at all so im sure you will aswell. Quote Share this post Link to post Share on other sites
jonrb 0 Posted January 20, 2007 I can only guess that Vince intends to map the car to run on SUL only. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted January 21, 2007 I thought he mentioned that he's going turbo or has a turbo. Raising compression on a turbo motor is normally something you don't want to do. For turbo you'd probably want to bring compression down to 9:1 or lower depending on boost level. If your running low boost stay with stock compression. Quote Share this post Link to post Share on other sites
jonrb 0 Posted January 21, 2007 I thought he mentioned that he's going turbo or has a turbo. Raising compression on a turbo motor is normally something you don't want to do. True, but I confess that I've slightly hijacked the thread and we were talking about NA use in that instance. :) Yes, for turbo installs you don't want to raise the CR, in fact you often want to lower it. Quote Share this post Link to post Share on other sites
vdubjb 0 Posted January 21, 2007 It does raise the CR but it hardly makes any difference at all.Not worth it IMO The stock fibre ones arent as well made. The metal ones are tougher and not much more expensive. The slight bump in power is worth it too. Quote Share this post Link to post Share on other sites
