dnac 0 Posted January 24, 2007 I was wondering how the fan switch works that is attached to the rocker cover on the 16v engines I take it is some sort of temperature activated switch, but is this based on engine bay temp or the rocker cover temp. The reason I am asking is that I believe mine is not working, as in tracffic the temp goes right up, to around 100 deg I have taken the wire off the switch and earthed it and the fan does come on, so either its broke, or as I have painted the rocker cover, perhaps its not seeing the correct temperature? Quote Share this post Link to post Share on other sites
steveo29 0 Posted January 24, 2007 thats the switch for running the cooling fan when the engine is off you want the one in the lower rad Quote Share this post Link to post Share on other sites
dnac 0 Posted January 24, 2007 Thanks, I'll take a look at that one Quote Share this post Link to post Share on other sites
khurrado 0 Posted January 24, 2007 Yeh that is the radiator cut off switch. Quote Share this post Link to post Share on other sites
