G60Dan
**New Clocks - oil warning light coming on? HELP**
Just replaced my 8V clocks with some 16v clocks. Problem is, as soon as I pull away, my oil warning light comes on & starts to scream!! Stays on till the ignition is turned off. The car is a 20vt, so I'm guessing the oil warning light wouldn't have been connected with old clocks!! ?
Why does it keep coming on??
I'm sure I've seen 160mph clocks in over 20vt's before though??
I don't care if the oil buzzer isn't conected? I'll buy an seperate gauge! I just want it to turn off.
It's not the level oil, it's sitting just under the max HELP!!!! Thought I'd put it up here too, one of you guys might know something?
Cheers
Dan
this happened to me once in my golf. i disconnected the battery and re connected and it cured it.
If not, your guna need to earth the oil pressure warning light wire i think?
Found this guide, anyone help?
Dash plugs (I think, after much head scratching!!):
T7 - white plug, short side
T7a - black plug, long side
T7b - white plug, long side
T7c - black plug, short side
A
1 - gry/blu- light switch pin 58b (dash light dimmer)
2 - grn - wiper stalk pin 53
3 - blu/yel- dash plug pin T7b/7 (upshift control light)
4 - blu/blk- dash plug pin T7c/4 (oil pressure control unit, 0.3 bar feed)
5 - grn/yel- wiper stalk pin 53b
6 - grn/blk- wiper stalk pin 53e
7 - blk/grn- hazard switch pin R & indicator switch pin R
8 - blk - ignition switch pin 15
9 - wht/blk- light switch pin 56
10- blk/grn/wht- hazard switch pin 49a & indicator switch pin 49a
11- blue/brn- spare plug behind fusebox? (indicator relay pin 2)
12- brn/blk- wiper stalk pin J
13- blk/blu- hazard switch pin 15
14- grn/wht- wiper stalk pin L
15- grn - fusebox pin B/1
16- blu - dash plug pin T7a/5 (alternator warning light)
17- blu/red- dash plug pin T7/7 (indicator warning light)
18- wht - hazard switch pin 49
19- grn/red- wiper stalk pin T
20- blk/wht- hazard switch pin L & indicator switch pin L
21- yel - indicator stalk pin 56b (headlight flasher/main beam switch)
22- blk/yel- rear window heater switch pin + and heated seat switches pin 15
23- blk/red- glovebox light and fresh air blower switch pin + or A/C switch pin +
24- gry/grn- light switch pin 58 (dash light dimmer)
25- blk/yel- fusebox pin L/1
28- blu/wht- dash plug pin T7/1 (high beam warning light)
B
1 - grn - fusebox pin A/15 and dual circuit & handbrake warning light
2 - grn/wht- fog light switch pin 83b (fuse #17)
3 - vio/blk- dash plug pin T7/5 (fuel gauge)
7 - yel/red- dash plug pin T7b/6 (coolant temp gauge)
8 - red/blk- ignition switch pin 50
9 - blk/gry- wiper stalk pin 53a
10- blk/yel- light switch pin X
11- gry/red- cig lighter
\- red - radio power plug pin 7
12- red - digital clock/MFA
13- red/yel- indicator stalk pin 30 (headlight flasher/main beam switch)
15- yel - dash plug pin T7a/4 (oil pressure control unit, 1.8 bar feed)
16- wht/yel- fog light switch pin 83a
18- blk/grn- upshift/fuel consumpton indicator solonoid shut-off
19- red/blk- dash plug pin T7b/4 (rev counter)
20- grn/yel- fog light switch pin 83
21- wht/grn- rear window heater switch pin 86
22- wht - indicator stalk pin 56a (headlight flasher/main beam switch)
23- red - light switch pin 30
25- brn/blk- fusebox pin L/2
26- gry/red- light switch pin 58R
27- gry/blk- light switch pin 58L
28- red/wht- hazard switch pin 30
C
1 - red/blk- brake light switch
2 - blu - alternator pin D+
3 - red/yel- brake light switch
4 - grn/blk- left parking light bulb
5 - yel/wht- left headlight bulb pin 58b
6 - yel - right headlight bulb pin 58b
7 - red - radiator fan thermal switch & radiator fan after-run relay pin 30
8 - blk/grn- right front indicator & repeater
9 - grn/red- windscreen washer pump pin +
12- blu/brn- brake fluid level warning switch
13- blk/yel- dual tone horns
14- grn/red- right parking light bulb
15- brn/blk- dual tone horns
16- wht - right headlight bulb pin 58a
17- wht/blk- left headlight bulb pin 58a
18- red/blk- thermo switch for cold start valve (K-Jet f/inj) or digifant ECU pin 1
19- blk/wht- left front indicator & repeater
20- blk - radiator fan run-on control unit pin 2/15
22- wht/yel- foglights
D
1 - blu/blk- oil pressure switch (0.3 bar)
2 - blk - thermal switch for inlet manifold heater (carb models) or fusebox pin R/1 (digifant f/inj) or idle & WOT switches
\- blk/wht- idle overrun cut-off valve (carb models)
\- blk - knock sensor control unit pin 5
3 - wht/grn- fuel gauge sender or transmission switch/upshift indicator
7 - blk/yel- low coolant level switch unit pin 6/15, idle boost control unit pin 2/15 (K-Jet f/inj)
8 - wht/red- vacuum switch/upshift indicator
9 - grn/yel- windscreen wiper motor pin 53b
12- grn - windscreen wiper motor pin 53
13- vio/blk- thermal switch for carb heater, inlet manifold heater, auto choke & bypass cut-off valve (carb models)
\- red/yel- electronic ignition control unit pin 10 (16v) or digifant ECU pin 3 (digifant f/inj)
\- red/yel- knock sensor control unit pin 10 (16v)
15- wht/vio- resistance wire -> ignition coil pin 15
16- blk/red- reverse light switch (M/T) or starter/inhibitor & reverse light switch pin 15 (A/T)
17- grn/blk- windscreen wiper motor pin 53e
19- blu/blk- reverse light switch or starter/inhibitor & reverse light switch pin R & diode (A/T)
20- blk/gry- windscreen wiper motor pin 53a
21- yel - oil pressure switch (1.8 bar)
22- br - windscreen wiper motor pin 31, and spare connector behind fusebox or to earth 'claw' near fusebox
23- blk - ignition coil pin 15
24- red/blk- starter pin 50 (M/T) or starter/inhibitor & reverse light switch pin 50 (A/T)
26- red/blk- ignition coil pin 1 & idle control unit pin 1 (K-Jet f/inj), overrun cut-off valve (K-Jet f/inj)
29- yel/red- coolant temp sender
\- yel/blk- low coolant level switch unit pin B/G
E
1 - gry/grn- number plate lights
2 - grn/blk- rear wiper motor pin 53
3 - red - interior light & boot light
5 - vio/blk- fuel pump or fuel gauge sender pin G
6 - blk/wht- left rear indicator
7 - grn/red- windscreen washer pump pin 31 (rear pump on earlier models)
\- brn/blu- windscreen washer pump
8 - blk/gry- rear wiper motor pin 53a
9 - grn/blk- left rear light
10- grn/wht- rear foglight
11- blk/grn- rear right indicator
12- blk - reverse lights pin RF
13- grn - handbrake warning switch
14- red/wht- warm up regulator, aux air regulator & control pressure regulator (K-Jet f/inj)
\- red/yel- main & transfer fuel pumps
15- wht-wht/grn- rear window heater and heated mirror glass
16- blk/red- brake lights pin 54
18- grn/red- rear light bulb
G
1 - blk/yel- Electric mirror adjustment switch pin 5 & electric window relay pin 6/86
2 - blk - heated washer jets, spare plug behind fusebox & idle stabilser valve pin 2/15
3 - blk/yel- heated seat control units pin 17/15
9 - gry/grn- headlight washer relay pin 5/56
10- grn/red- headlight washer relay pin 4/5
H
1 - red/wht- radiator fan thermoswitch & A/C refrig. high pressure switch
2 - red/blk- A/C switch
3 - red - Battery +ve
4 - grn/yel- A/C thermostat
5 - yel/red- fresh air fan switch pin 4
6 - blk - fresh air fan
K
5 - brn/red- ignition switch pin S or SU (difficult to make out!)
L
1 - blk/yel- fusebox pin A/25
2 - brn/blk- fusebox pin B/25
3 - brn - earth location 16 or 81
4 - brn/blu- horn switch
M
N - red/wht- inlet manifold heater
\- red/blk- f/injection relay pin 86 (K-Jet f/inj)
P - red - battery +, ignition switch pin 30, electric window relay pin 87, headlight washer relay pin B/30 & f/injection relay pin 30 (K-Jet f/inj)
R
1 - blk - fusebox pin D/2 (digifant f/inj)
2 - blk/yel- digifant ECU pin 14 & fuel injectors (digifant f/inj)
Thanks
Just find the 2 oil pressure senders (1 white,1 blue?) the wires are 1 yellow and 1 blue i think?
1s for low pressure and 1 for high pressure
going to earth the yellow on its own and see what happens. I don't want to start chopping in to other wires and creating more problems.
