Stan 24v
Mrs Stan 24v's Golf 4motion - New wheels
this is my latest log
Friday,02,March,2007,17:15:34
VAG-COM Version: Release 607.3-UD
Control Module Part Number: 022 906 032 CP
Component and/or Version: MOTRONIC ME7.1.1G 6463
Software Coding: 0000132
Work Shop Code: WSC 00000
10 Faults Found:
19475 - Valve for Exhaust Flap 1 (N321): Open Circuit
P3019 - 004 - No Signal/Communication - MIL ON
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16690 - Cylinder 6: Misfire Detected
P0306 - 008 - Implausible Signal - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 008 - Implausible Signal - Intermittent
16685 - Cylinder 1: Misfire Detected
P0301 - 008 - Implausible Signal - Intermittent
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded
17560 - Long Term Fuel Trim Additive Air; Bank 1; Range 2: System too Lean
P1152 - 001 - Upper Limit Exceeded
17559 - Long Term Fuel Trim Additive Air; Bank 1; Range 1: System too Lean
P1151 - 001 - Upper Limit Exceeded
17498 - Mixture Regulation; Bank 2; Range 2: Lean Limit Exceeded
P1090 - 001 - Upper Limit Exceeded
17497 - Mixture Regulation; Bank 2; Range 1: Lean Limit Exceeded
P1089 - 001 - Upper Limit Exceeded
Readiness: 0000 1001
runs like a bag of spanners.
Looks similar to mine mate. I'll change my MAF over tomorrow and see what happens. I'll let you know how I get on. If you manage to get anywhere with yours, let me know.
Woohoo!!!
Ive got it sussed!!! Swapped the MAF from my Corrado (4motion engine) over to the golf and hey presto, it works!!! It was the MAF fault code at the bottom of my readings all along.
You going to Ultimate Paul? If so you can swap my MAF over to see if it works.
looking like an inlet air leak somewhere.....or that blasted number 3 plug that didn't feel very nice when I tightened it up.....
You wanna part with one of those spare MAFs mate? I need to get another now as the one in the 4mo is off my C :roll:
Drove in to work this morning, been raining all night, felt a little lump under load again and had a flashing engine light again :mad:
However, it hasnt stayed on this time, so its not a hard latch fault. Gonna vag-com it again tonight to see the codes. Maybe the coil pack is fooked after all???
Got some new codes:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 022 906 032 E
Component and/or Version: MOTRONIC ME7.1 V007
Software Coding: 00132
Work Shop Code: WSC 31414
4 Faults Found:
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-10 - - - Intermittent
17516 - Oxygen (Lambda) Sensor Heating: B2 S1: Performance too Low
P1108 - 35-10 - - - Intermittent
P0300 - 35-00 - -
16688 - Cylinder 4 Misfire Detected
P0304 - 35-00 - -
And from the Wiki:
17511/P1103/004355 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
Possible Solutions:
* Check Oxygen Sensor Heating for Oxygen Sensor before Catalytic Converter
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Possible Causes
* Air Intake System leaking
* Fuel Supply faulty
* Injector(s) faulty
* Ignition Cable(s) and/or Spark Plug(s) faulty
* Ignition Coil(s) faulty
* Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
* Camshaft Position Sensor (G40) faulty
Possible Solutions
* Check Misfire Recognition
* Check Air Intake System
* Check Fuel Supply
* Check Injector(s) and Injector Sealing
* Check Ignition Cable(s) and Spark Plug(s)
* Check Ignition Coil(s)
* Check Exhaust Gas Recirculation (EGR) Valve (N18)
* Check Camshaft Position Sensor (G40)
Special Notes
* This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
16688/P0304 - Cylinder 4 Misfire Detected
Possible Causes
* Ignition system
* Fuel injectors
* Fuel pressure
* Running out of fuel
* EVAP canister purge valve
* Evaporative emission system
* Low compression
* Base engine problems
* Controle Module damaged
Special Notes
* This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
Anyone got any ideas? Could it be the Lambda's, or the coil pack, or something else????
Aint having much luck are you stan..... Don't worry i'm sure you'll get it all sorted....
I rekon its the coil pack too.... :)
Would that cause the lambdas to play up though?
No, not much bloody luck, but thats what happens (sometimes) when you buy a cheap car :(
You should see how much i've spent on what was a cheap car when i bought it mate! I could be driving a porker instead!
Lambda i reckon....
how does it know the lambdas are performing poor?
if the coil pack is playing up, then it could be firing fuel out the exhaust and onto the lambdas. Its too much of a coincidence them both failing at the same time.
Had problems with my Mk4 Golf GTI. Use to lose the revs completly at speed - was very dangerous! I'd have my foot to the floor and the engine gave nothing for seconds, then all of a sudden the power would kick in. Thought it was coil packs, but turned out to be a dodgy MAF, so got a new one.
Already changed that.
Going for coil pack next. On a plus side, it passed the MOT today :D
im having this prob at the mo, changed the MAF and it did help but still a bit retarded so the lambda probe is next and codes also say i have a misfire on cylinder 1
Bit of an update. Recently changed the front wishbone bushes, and ARB bushes, all for powerflex and its made loads of difference!!!
I also bought some Santa Monica's off ebay a while back, and have just wrapped them in Eagle F1's and stuck them on the car. The last owner had them refurbed in a gun metal grey colour, and I think they look quite ace!!!
So I still have 24v to play with when needed :wink:
Opinions on the wheels?
