shephard
what do you think
ok my 1.8 16v corrado that i bought from someone who had it sat in there garden for 18 months has just had a pre mot, it needs o/s cv boot gaiter changed, horn not working, there is a brake fluid leak from the reservoir pipe, hand brake low effort, also brake pipes to and from o/s/r hose corroded, they told me £300 ish to fix what do you think, does anyone know where i can get the reservoir pipe and what pipe is it for the rear that is corroded please, thanks
My quote :
Both Wipers Knackered
Dip Beam NW
Brake Lights NW
Steering rack gaiter insecure
Parking Brake Crap
Small weld under battery
Which effectively comes down to : 2 wipers, a switch, a ziptie, a fuse, 94 seconds of welding, and a bit of a faff with the rear brakes.
And the price they wanted? £250 trade.
Hope that helps.
Steve
P.S. Flusted : Couldn't pass on any tips on the HB could you? I'm due for a go at this as well...
well remove calipers,wind piston out on caliper so the pads very lightly bind,then fit back together.
new handbrake cables are cheap and make a difference
