mattcorrado 0 Posted February 18, 2007 Hello , i have just brought a vw corrado 1991 16v shes lovely. But the revs seem to stay at 3000 rpm , i have changed the air filter which helped a bit but is still hanging the revs at 3000 rpm. Also there is a loose part in my engine bay can anyone tell me what it is , i can send pictures to you via e-mail (mailto:[email protected]). It's a black wire with a bolt at the end with a spade termial attached to it which attaches to the black wire. As i say i can send pictures but this id bugging me i spent 4 hours seeing if i could see were it came from . hope someone can help thanks Matt Quote Share this post Link to post Share on other sites
s.g 0 Posted February 18, 2007 if you post some pics up then i am sure someone will be able to help. Quote Share this post Link to post Share on other sites
mattcorrado 0 Posted February 19, 2007 if you post some pics up then i am sure someone will be able to help. Quote Share this post Link to post Share on other sites
mattcorrado 0 Posted February 19, 2007 Hi these are the pictures of the part . I've had a look in the haynes manual and other book's but still can't find were it goes and what it is . a a a a a gggg h h h!! I have a feeling it may be an oil temp sensor or something like that. Cheers Matt Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted February 19, 2007 That rings a bell- is it from the top of the oil filter? Quote Share this post Link to post Share on other sites
g60bv 0 Posted February 19, 2007 it looks like a fan run on stat. Quote Share this post Link to post Share on other sites
g60bv 0 Posted February 19, 2007 it looks like a fan run on stat. earth it out . the fan should start whurring Quote Share this post Link to post Share on other sites
g60bv 0 Posted February 19, 2007 opps sorry. silly back botton. Quote Share this post Link to post Share on other sites
blue95 0 Posted February 19, 2007 Is this not held down by one of the rocker cover bolts??? Will need to check on mine, pretty sure it goes on the corner of the rocker cover nearest to the alternator. Feck knows what it does though LOL :lol: Quote Share this post Link to post Share on other sites
owensluke 0 Posted February 19, 2007 Hey mat i have the same problem with my corrado revs staying at 3000 even when the clutch is down when changing gear i have changed the idle control valve checked all the vacum pipes for leaks cleaned the throttle body but still the same problem i am just to change oil temp sensor number2 to see if that works if you have any joy let me know cheers Luke Quote Share this post Link to post Share on other sites
nocrap 0 Posted February 20, 2007 1 pin black sender should be the temp gauge sender, but that's the wrong side of the engine. Certainly a sensor of some sort, probably wont be oil pressure as you car would be shouting at you..... Quote Share this post Link to post Share on other sites
Dec 1 Posted February 20, 2007 It's the fan overrun switch :wink: As blue95 said it bolts onto the front left hand side (as you facing the engine) of the rocker cover, nearest the alternator. Quote Share this post Link to post Share on other sites
g60bv 0 Posted February 20, 2007 actually what G60BV said... :) Quote Share this post Link to post Share on other sites
