vwdeviant 0 Posted March 14, 2007 Any-one got the part number for the blue coolant cap on the expansion tank? '92 2.0l 16v (if this makes a difference) Noticed at the weekend I've still got a black one and want to bung one on for insurance... Problem is the local (to me at work) Stealer's is in the City and they get parts shipped in so would like to get this done as smoothly as possible, without the usual: "It's for a 2.0l 16v Corrado" "Uh Cordoba, that a Seat...?" "C-O-R-R-A-D-O" "Erm.... A what?" "Oh for feck's sake, it's a Mk2 Golf/ Passat.." "Ah right yeah we can get bits for those!.." Quote Share this post Link to post Share on other sites
coolrado 0 Posted March 14, 2007 not sure what the part number is for the new blue ones but if you give them the part number off the old one they should be able to find it. when i recently had problems with coolant loss from the header tank (turned out to be head gasket) i noticed they had the nice new blue caps on the shelf in halfrauds so i picked one up while i was there, i fitted it and it seemed fine until i removed it to top the coolant up and it left the black section with the pressure relief valve stuck in the top of the bottle, all of the clips that held it together had snapped off and it was a real pita to get back out, so definately avoid pattern part caps. Quote Share this post Link to post Share on other sites
nocrap 0 Posted March 14, 2007 Blue caps can be bought from here http://www.vwspares.co.uk/corrado_cooling.php Quote Share this post Link to post Share on other sites
davidwort 0 Posted March 14, 2007 when I asked GSF for a new cap a few years back the blue one was what I got, didn't seem to have anything else. Quote Share this post Link to post Share on other sites
Yandards 0 Posted March 14, 2007 I think one of the reasons they are blue is that the earlier black ones had some issues with pressure relief valve, you can only get blue coloured ones now but if you give them the part number from the black one ETKA should provide the newer blue one as a replacement. Quote Share this post Link to post Share on other sites
vwdeviant 0 Posted March 14, 2007 Cheers, will try and remember to get that tonight when I get in... (if the old brain's still awake) Are everyone else's caps large and (sort of) flat as opposed to earlier small domed ones? Quote Share this post Link to post Share on other sites
Toad 0 Posted March 14, 2007 when i recently had problems with coolant loss from the header tank (turned out to be head gasket) i noticed they had the nice new blue caps on the shelf in halfrauds so i picked one up while i was there, i fitted it and it seemed fine until i removed it to top the coolant up and it left the black section with the pressure relief valve stuck in the top of the bottle, all of the clips that held it together had snapped off and it was a real pita to get back out, so definately avoid pattern part caps. If anyone ever has this problem again, warm the car up (not till it's really hot or owt) and slowly updo the cap. the pressure will push the centre section out. And you'll lose some water. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted March 14, 2007 1H0121321C i think thats it, my receipt just says "cover" and it was when i bought coolant so i assume thats the cap Quote Share this post Link to post Share on other sites
craigowl 0 Posted March 14, 2007 Yep - same no. as mine. A flattish blue job I got in September last year. Price £5.75 incl VAT. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 14, 2007 Halfords also do them Quote Share this post Link to post Share on other sites
coolrado 0 Posted March 15, 2007 Halfords also do them yeah but as i mentioned before ^^^^^ they are crap :lol: definately worth buying a genuine one as the halfrauds ones are badly moulded and made from dried out weetabix :wink: Quote Share this post Link to post Share on other sites
L100PY_H 0 Posted March 15, 2007 There was somebody on here recently selling the later, wider blue caps that are easier to pull off, cannot for the life of me remember who...but will keep searching mate! Quote Share this post Link to post Share on other sites
nocrap 0 Posted March 15, 2007 That was for the washer bottle matey.... Quote Share this post Link to post Share on other sites
gogsboy 0 Posted March 26, 2007 it was a real pita to get back out, so definately avoid pattern part caps. How did you get all the gubbings out the tank, my Halfords blue one has self destructed and left bits everywhere inside the tank. Easy enough to get the spring etc back out but not the particals of plastic Quote Share this post Link to post Share on other sites
coolrado 0 Posted March 26, 2007 it was a real pita to get back out, so definately avoid pattern part caps. How did you get all the gubbings out the tank, my Halfords blue one has self destructed and left bits everywhere inside the tank. Easy enough to get the spring etc back out but not the particals of plastic ah mine wasnt quite that bad, it just broke loose from the cap and left the black pressure relief valve section in the bottle which i managed to get out by drilling a self tapping screw into it and pulling it out. if there are loads of bits in the bottle it would probably be best to remove the bottle and shake all the bits out or buy a new bottle from the stealers, not much more than a tenner last time i checked and a nice new bottle looks good in the engine bay. Quote Share this post Link to post Share on other sites
gogsboy 0 Posted March 27, 2007 New bottle sounds good, I'm just worried little bits of obliterated plastic have found their way into the system somehow Quote Share this post Link to post Share on other sites
