MurphG60 0 Posted April 9, 2007 Hey All, Was wondering what the minimum wheel size would be for my Rado since im running Brembo 4 Pots and 305 mm discs on the front, i saw an Ibiza Cupra running 15'' rims at York Raceway and he had the same kind of setup on the front looked tight. Are the hubs completly different sizes on the two cars hence he can run small rims???? Just im not happy with having 17's on me car want to go 16'' or if poss down to 15'' without ditching me brakes which are great.... Thanks Murph :) Quote Share this post Link to post Share on other sites
just_say_meth 0 Posted April 9, 2007 Got a friend running the LCR 4 pot brembos with 16" compomotive MO's on a golf and the calipers are tight as!! Probably about 2mm clearance at each of the mounting bolts. So 16's are possible Quote Share this post Link to post Share on other sites
DANG60 0 Posted April 9, 2007 Mine are 16's and fit over my brembo four pots. Quote Share this post Link to post Share on other sites
MurphG60 0 Posted April 9, 2007 Where abouts are you at Dan would be good to have a look.... Quote Share this post Link to post Share on other sites
DANG60 0 Posted April 9, 2007 http://www.vagcars.co.uk lol (the green screwcharged c) Il try n get sum pics up for ya, they are close like and theres no room for weights so they have to be balanced at the back Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 17, 2007 305mm Brembos fit under 15" compomotive 5 spokes...... hence why it's a popular wheel for tracking and dragging. It's not the spoke / hub clearance, it's the inner diameter of the wheel that allows this. Quote Share this post Link to post Share on other sites
JMC 0 Posted April 17, 2007 I've got 305mm disks and Porsche calipers under my 16" MO's, and it;s farily tight, but not "down to the millimeter" tight. Quote Share this post Link to post Share on other sites
MurphG60 0 Posted April 17, 2007 Where is the best place to et some of them??? Quote Share this post Link to post Share on other sites
JMC 0 Posted April 17, 2007 Bought my Compomotives straight from Compomotive (had them made with an extra 5mm offset to space the wheels out a bit more and give me some more clearance).... Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted April 17, 2007 Not all 16" wheels will fit over the Brembo set-up, but quite a few 17" will as long as at least 7.5" wide. Quote Share this post Link to post Share on other sites
MurphG60 0 Posted April 17, 2007 Yeah but im looking to go lower in diameter for track days and strips..... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 18, 2007 Well MOs are about your lot then.... Quote Share this post Link to post Share on other sites
MurphG60 0 Posted April 18, 2007 Sorted will try and get me hands on some... Thanks Guys.... :D Quote Share this post Link to post Share on other sites
DANG60 0 Posted April 18, 2007 mine are speedline comp 2's mate and my brembos fit under them, the only down side is they need balancing on the back as the weights wont clear the calliper lol. Quote Share this post Link to post Share on other sites
