andy
288mm Brake Spares
I got some used 288mm calipers/carriers last year, however I've only just looked at them. Whilst they're generally quite tidy I have 2 problems.
Firstly there is a split in one of the piston rubbers, can I get/fit another one, if so where from etc.
Secondly one of the slider pins is missing, I see these only screw in, are they available seperately? Has anyone got one by any chance.
Needless to say the seller will be getting a PM....(not this forum)!
Thanks in advance.
I think id be tempted to give them back to the seller and ask for a refund...
Although i dont know the details im sure youll be able to get the bits you need..
Trouble is that it was a year ago, I think its probably our friends at the delivery company who have damaged them. I should have had a proper check on arrival....
The rubberseals are less than a £10er from VAG but the slider may be more difficult to locate as there come with the carriers IIRC... maybe try a brake specialist...
Can someone confirm how many slider pins you get on 288mm brake setups, the type I have in front of me have 2 per carrier (or should have!) I've just spoken to VW and they think there should only be one per side. Anyone got a picture of the usual 288mm setup, ie carrier and/or carrier?
Dumb question i know but what is a slider pin ??
Probably not the official name, but its the pins that screw into the carrier that the caliper slides on (when brakes applied and as the pads wear).
