kongo127
G60 CO Emissions...
I know this subject has been covered several times before, but i guess that´s our posts who keep the forum alive, otherway this would seem like an ordinary library... :)
So i took this morning to give some good threatment to my 1992 Jet, i ended up by setiing the CO value.
I don´t own a wideband, neither know anyone who does. :(
I wonder if somebody can tell me which % of C0 is measured when the car is properly set-up at stoichometric point 14,7:1
All cars are diferent, but i guess that there´s a nominal value? 8)
By the way, i strongly suggest all G60 owners to check up their lambda´s millage, check igniton timing and CO.
I did this today and the car runs much better! :D
At the first time i thought that it was only my imagination... LoL But then i realised that even the exhaust sound is different!
I love G60´s!!! :D
Cheers,
mine was about 0.25 on the c/o meter with the wideband showing the correct reading and the c/o pot at 450ohms
Hi Steve!
Quality and useful information you left there! :)
I guess that´s a good start, apart from not having a wideband.
But... 0.25% CO seems very low...
Maybe you meant 2.5%???
I´m running with a cat, where in the exhaust pipes did you get that reading?
i have no cat...and im sure it 0.25 c/o (not saying its right mind you)
pitstop told me not to worry too much what the tailpipe said as long as it passes mot...just make sure c/o pot is 450 ohms
took mine for an mot recently
CO was 0.13
HC was 20 ppm
MOT tester said that it seemed very low and was better than some of the new cars
No Cat on mine or Lambda
As long as it passes suppose its all good huh?
