kop10320178
koni`s and h&r springs (where can i get them from)
hi, i own a 94 rado vr6
which koni`s do i buy ?
there are yellow shortened koni`s
and special red koni`s
which ones do people normally marry up with the h&r springs?
where can i get them from what settings do you normally set the shocks at?
would appreciate the help as my shocks are cabbaged.
thanx jay
for the dampers at least:
try some searching on the forum, I've posted up the koni data sheets before but a bit of 'Googling' will find them, the koni site should give info on UK distributors, mail order may be the cheapest though.
you will need yellow, koni sport Top Adjustable (TA) dampers, these can be safely run with lowering springs, different versions are available for 4cylinder and vr6 cars and some rears are not TA's but adjustable off the car, for early cars you can just purchase inserts for the front VAG legs. I run mine at minimum settings, too bumpy otherwise, although I have Eibach springs instead.
I just spotted that Star Performance in Fife deal in both products so shall try there. I am sure they know the setup well.
