Toad
Early rear springs and shocks on late VR
I've had a thought about my VR. I've got a set of spare standard early 16v rear springs and shocks, which leave the car sitting sensibly at the rear, rather than the overly high VR6.
Could I swap them over to lower the rear of the VR? I can't see why not...
Cheers.
Tom
Im fairly sure this will be ok, the front is the area where you cant swap due to the weight difference and hence the different spring and damper rating...
