Twiss 0 Posted July 9, 2007 Got a question that I can't find an answer to in the search. My 1.8 kr fuel management is mechical, I would like to put a turbo on it. I was wondering would it be possble to fit a EFI now on the standard engine and have it tuned to work? I was thinking of just getting the g60 loom and wiring or would another fuel maganement be better? Could any one recommend where this could be done? Thanks Vaughn Quote Share this post Link to post Share on other sites
Crasher 3 Posted July 9, 2007 It would be easiest to add a piggy back controller to add fuel when needed and alter the timing as required. Switching to EFI is a huge task and you would be better to rip out the KR and fit a 1.8T unit with an aftermarket ECU. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 If you have the skill/facilities fit the Weber/iaw injection system off various lancias,ford cosworths etc,the difference in power delivery/driveabiltiy between the two(Digi 1 vs iaw) is quite something. I'm going to be taking some photos today of my set-up so you can see what's involved component wise,no more digi-lag,uncertain power delivery,any choice of injectors,2 MAP sensors(black and 3 BAR grey,as fitted O/E to the Lancia evo's),no more crumbly injector wiring harness and it's quite easy to re-programm using an emulator. Quote Share this post Link to post Share on other sites
Twiss 0 Posted July 13, 2007 Thanks Veedubbed That would be really usefull and intresting to get an idea of the work involved. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Here are a few photos of my car's set-up,let me know if you need help identifing any thing. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Weber ecu in place of the old 9A or digifant 1. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Dist. and Ford escort cossy HT magnacore leads. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Charge air temp. sensor on modified G60 throttle body(Weber/iaw throttle switch is fitted underneath next to the boost return...) Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Fuel pump/ignition,injection control relais. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 The all important twin MAP 2+3BAR sensors hidden. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 TDC chopper disk and relative TDC sensor and home brewed bracket! Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Various throttle bodys i used before,some were ok but others were like on/off switchs in traffic,the best is the O/E G60 jobbie,IMO. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Different types of throttle Pots. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Weber knock sensor bolted in place of the O/E 9A's version,even the bolt's the same! Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Fiat/Lancia FPR. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 13, 2007 Lancia delta integrale evo1 ecu,you can also use many more such as Lancia delta 4wd,hf turbo. Depends on what boost you'll be running. Quote Share this post Link to post Share on other sites
DanVW 0 Posted July 13, 2007 Very nice! :-D what are you running bhp/torque wise with that lot? Quote Share this post Link to post Share on other sites
Twiss 0 Posted July 13, 2007 WOW ok I'm impressed did you have to do any thing to the fuse box for the ignition ? or any thing to the existing wiring? Don't know if your know this but as Mine is the KR block Will mine have the plug for the knock senser? Quote Share this post Link to post Share on other sites
Twiss 0 Posted February 21, 2008 Well I've had trouble finding a IAW fuel system. with out it costing the earth so it looks likei'll have to go go downt he digi 1 root. So as i'm aware ( i've bound to of forgotten a few things i normal do) i need the engine loom, ecu, sensers from the engine like knock senser, crank etc g60 TB Any thing else? My current engine spec is a 2.0l (6A block and head) will have the KR inlet cam in it running k-jet on a 1990 Corrado. Ive searched the forum for some info on fitting it but have not had much luck. Any how any help would be appreciated. Quote Share this post Link to post Share on other sites
flusted 0 Posted February 21, 2008 fuel rail and a way of running the bts. check my members gallery thread, ive just done this Quote Share this post Link to post Share on other sites
