will 2
anti roll bar removel
hi, i have been through the search and cant find anything on removing the arb, can any one give me a quick rundown on this issue :)
i have taken most of it appart but am unsure if the subframe has to come down a bit
thanks
Hi mate,
I changed the ARB bushes last month on my vr and i had to lower the rear subframe slightly. Support the subframe with a trolley jack and then there are 4 bolts you need to undo. First obviously you need to remove the 4 small bolts holding the ARB in place, then there are the 4 sub frame bolts, 2 which hold the rear of te wishbones to the chassis and 2 actually bolted to the chassis itself. You completely remove the 2 from the wishbones and just loosen the 2 on the chassic do not remove completely, then its just a case of slowly lowering the trolley jack until the ARB can be removed. You may need to keep going back and loosening the sub frame bolts a tad more until the ARB can slide out, just try not to loosen them too much as apparently you can cock up the alignment!
Its not too hard, i managed to do it so im sure you can :lol:
Rob.
great, thanks for that, got it out just hope the new one turns up tomorrow for me to get it back together cheers gareth 8)
