jon daniels
wheel bearing
hi, doea any one know the size i need socket wise for the main hub nut on the front wheel to change the wheel bearings? my rado is a 89 1.8.
has anyone done one on one of these? i have done wheel bearings before just not on a rado.
any any ideas?
cheers jon
24mm I think
you'll need a massive breaker bar though, they are f£$%^&g tight, and you really need a press for the bearings, I took the hub off the car and got a local factors to press the new bearing in for me.
cheers mate, yeh i know what you mean about the nut bieng tight, i have access to a press so hopefully will be ok.
local garages charging a small forune for each side.
cheers again
