sim0n_parker 0 Posted August 23, 2007 on the bay is a newman camshaft for 8valve vw engines with hydraulic tappets, they list the 268degree cam and 272 degree cam? anyone used these? im thinking of one for my G60 is it worth it? they are 150 plus postage Quote Share this post Link to post Share on other sites
g60bv 0 Posted August 23, 2007 i have one and find them a bit lumpy. nothing special at all. cheap. try the piper 270h instead Quote Share this post Link to post Share on other sites
flusted 0 Posted August 24, 2007 shrick is highly recommended Quote Share this post Link to post Share on other sites
g60bv 0 Posted August 25, 2007 also it worth noting, the lift on the newman is so massive. you have to grind the edge off the port which holds the hydralic lifter. this alone is a pain in the arse. unless you have access to a an air grinder, you have a cylinder head full of aluminimun. which of course you can get out. and it only takes a small amount to knacker a lifter. then it all has to come out again., so no dont get one. Quote Share this post Link to post Share on other sites
philip walker 0 Posted September 27, 2007 The 264 Newman cam we sell should be a direct fit with no grinding as you suggests? The ideal duration for a G60/forced induction engine is 264 to 268 deg. Quote Share this post Link to post Share on other sites
g60bv 0 Posted September 27, 2007 these where g-werks spec g60 cams. i think they are ground to gwerks spec. to work with the cnc heads. Quote Share this post Link to post Share on other sites
Henny 0 Posted October 3, 2007 yup, as above, it's only the Newman cams that G-werks spec'd up to work with their CNC heads that needed the head modifying to clear the cam lobes.... Did mine with a dremmel as it was the prototype CNC head and the cam hadn't been spec'd up when I got it back, so they didn't machine it for me... only took about an hour to get a nice finish and clearance on all parts of the head and then about 10 minutes with a pressure washer to clean out all of the swarf... :lol: 8) Quote Share this post Link to post Share on other sites
g60bv 0 Posted October 3, 2007 of course, thats if the heads off the car.!! Quote Share this post Link to post Share on other sites
Henny 0 Posted October 10, 2007 good point, well made... :lol: Quote Share this post Link to post Share on other sites
Rimshot 0 Posted October 17, 2007 Sorry to hijack your thread mate but I didn't feel like a new one on this subject should be started. Just wondering what advice you guys could give me on a change of cams for a 1.8 16v? My friend suggested weber, I just need to know what the best power gains would be for the best (cheap-ish, considering the part) price? Thanks Quote Share this post Link to post Share on other sites
