foxhound81 0 Posted November 9, 2003 Hi, I'm looking at converting my 8v G60 over to 16v. I found a head from a jetta that's 1.8 16v, came outta a GLS i believe. I'm just checking to see if this head will bolt onto my G60's block. Any and all help is greatly appreciated. Thanks Quote Share this post Link to post Share on other sites
VR6 0 Posted November 9, 2003 I know nothing about the conversion, but I know that people in the know quote around £5,000+ for the conversion! Quote Share this post Link to post Share on other sites
W3RKD 0 Posted November 9, 2003 the 16v head will bolt straight on .... best thing to do is join up on the 16vg60 yahoo e.groups there are lots of people in the u.s who are undertaking this conversion and could save you $10000's in free info Quote Share this post Link to post Share on other sites
Henny 0 Posted November 9, 2003 Best bet is to ask/PM John (16VG60) as he's been running a 16VG60 for a while now and knows most of the ins and outs behind it.... 8) He's pretty good with dishing out the knowledge and has always been totally straight and honest with me... 8) Quote Share this post Link to post Share on other sites
h100vw 0 Posted November 9, 2003 Bahnbrenner sell all the gear, as do Kompessor Kanada. Both on your side of the pond. Lots of info an the stuff you need. Also check out http://www.vwvortex.com. Gavin Quote Share this post Link to post Share on other sites
foxhound81 0 Posted November 10, 2003 Yeah I was checking out the Bahnbrenner site. It says i'm going to need: a 16V Secondary shaft and gears complete What exactly are they talking about. Sorry but I'm new to some of this. My main concern was if the head would bolt right on or not, but the g-man answered that for me. Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted November 17, 2003 the shaft they are referring to is the intermediate shaft that currently drives your distributor and your oil pump on yuyour 8v,, the 16V has a distributor mounted on the end of a camshaft therefore you will need to use a 16 valve intermidiate shaft and the gear which drops in where your distributor is currently mounted along with the blanking off cap to drive your oil pump,,, Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted November 17, 2003 It may well bolt on, but then what do you do about the breather? 16v breathes through the block, G60 breathes through the head. Oh, and as for CR, have you even considered what will happen to that? bang an ABA cross flow 8v head on it and a turbo. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted November 17, 2003 a 16v on G60 pistons makes about 7:1 CR i believe. need pistons to do the job right. Quote Share this post Link to post Share on other sites
Henny 0 Posted November 17, 2003 Also, I thought that the 16V head requires specific pistons else the valves/head won't clear the pistons even when they're closed? There's more to this conversion that just strapping on a head... As I said before, have a word with John (16VG60) and he'll point you in a reasonable direction! 8) I agree with you as well PhatVR6 compression ratios are pretty important to consider when you're force inductioning your engine... If bolting a supercharger to a standard 16V engine is a bad idea, then just bolting a 16V head straight on is probably almost as daft! :? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 17, 2003 I thought the 8 & 16V head stud patterns are different aswell, or was I imagning that during some obscure daydream about VWs? K Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted November 17, 2003 i was under the impressin that the oilways are different aswell :? Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted November 17, 2003 and if you're going to need pistons anyway, then why use a G60 block? just go for a 2.0 16v setup and stick low compression forged pistons in that. But then you'll find the G-Lader is a waste of time, so you'll be looking at turboing it, in which case, you may as well fit a 1.8T and do it for half the build cost. Quote Share this post Link to post Share on other sites
16VG60 1 Posted November 18, 2003 Too much to list out on this thread, but hey why not try dropping me a line as Henny suggested, you could be the recipient of all the info you require to have a 16V conversion. I'm running this engine myself and just for starters, the head will fit straight onto the PG block, no the bolt pattern is not different the 8V niether are the oil/waterways, you will require different pistons, you will also require the intermediate shaft crank pulley and oil pump from the KR engine. Quote Share this post Link to post Share on other sites
foxhound81 0 Posted November 21, 2003 ...sniff looks like goodbye g60 badges Quote Share this post Link to post Share on other sites
