Thom
Ongoing problems....
Hi everyone!,
I still have the classic 9A problem of fluctuating idle spped and cutting out, though less frequently than before,
I've replaced/tested the ISV, cleaned out the intake and throttle body, checked all wires and connections, changed plugs/leads.
Anyone have any other ideas?
Also, I was considering buying a fault code reader, but have heard that these are not very helpful with the 9A, anyone have any experience of this?
cheers, Thom 8)
Check for air leaks between the metering head and the throttle body. Mine had similar symptoms and it was a split in the concertina rubbery bit that goes on top of the metering head.
Also worth checking that the dizzy is set correctly. Undo the nut that holds it in place, and turn very slightly clockwise or anticlockwise and see if that helps.
