emirc
Rear ARB bushing?
One quickie :)
rear axle.JPG[/attachment:17qu9wh5]
Im after refreshing my suspension components. In this picture, you can see circled rear ARB bushing. Is it replacable? How many of them do i need? I suppose two, as for the front ARB, but im not sure...
Also, is there one or two bushes that secures steering rack?
Thanks.
there is a rear anti roll bar inside the u shaped channel of the rear beam welded at both ends, and it does have a single rubber bush in the middle, all this really does is stop the anti roll bar from vibrating or bouncing and unless its completely knackered or missing its not worth bothering with, its also the same as the mk2 golf bush and is still availiable from vw.
