CaiosG60 PWR
ACHTUNG!!!! G60 owners!
Some of you may already know this but it is going to cost me a fortune.
Yesterday evening the bolt holding the bottom pully to the crank snaped!!!
This could mean nackerd crank, pulley and possibly valves in the head!
This could possibly be avoided by odering a new bolt from VW as they
have increased the tensil strengh of this now. If I had replaced this bolt for
a minimal amount it would have saved me what could come up to almost a
grand maybe. More than a new charger!!!!!!!!!!!!!!
I have only had the car for two fucking DAYS!!!!!!!!!!!!!!!!!!!
Any one got any advice or know of a cause for this let me know.
Think I understand that, Nigel :D
okay say the engine threw a con rod or something and thus the crank hit the bottom of the rod and that "locked" the engine as the crank became jammed. the force on the pulleys would be massive, and seeing as the crank pulley is the one that cannot move the bolt is the weakest part or the link between the two.
i'm not saying it wasn't the bolt, but its a strange one.
when i use to to race model boats we often saw engines blow and throwing con rods with some funny outcomes. the worst was a con rod going nearly all the way through the casting.
ive heard of these bolts failing...its usually after theyve been removed/refitted
just bad luck....hope it works out for you :)
Cheers steveo29, so do I!!!
G60Jet, I hope that it doesn't have even more internal damage than
predicted. The bolt sent by VW today was the wrong one so I will have to wait till
tomorrow to find out. I have spoken on the phone to Dubsport and Jabbasport, who
both say that this is a common problem.
If I try to look on the bright side. It is an oportunity to clean the whole engine and
re-enamel it. I would also, If I can find the extra money like to fit a cam kit or a
vernier puley, etc! I will probebly not find any extra money but I carn't help looking
at them in the catalogs!
So check your bolts condition! You can see it from the wheel arch.
i dont know who to ask...but...im sure they fail according to how tight theyre done up....i remember reading about it...its esential theyre done up right??
maybe ask on vwvortex g60 forum
good luck
8vg60, I'm in Oswestry, Shropshire!
I'm thinking if the valves are knackerd then I may as well spend a bit extra and get
a TSR ported, polished and gas flowed head. Is this a good idea, as I want to run a
reliable car? I am thinking of geting standard air box, pulley and chip back on
because I don't know anything about where and who fitted them! The chip I think is
Jabba sport's from around 1999. As for the pulley I have know idea. The pipper
cross air filter makes a horrid noise!! Anyone got any sugestions or ideas for things
to do while the engines in pieces, and the check book's open!!!
dazzyvr6, I think there's also somebody on here with a G60 who is from
Wrexham.
8vg60, Cheers for geting back to me! I am very intrested in geting a ported&
polished head off you. The garage are a bit behind so I'll ring you this evening if they
have managed to asses my head by then. I've been checking them Pirreli's, one
seems to have a little dent on the rim. I doesn't look major and I think that
its okay. But I will get it checked out at a garage. Apart from that there pritty mint.
Fortunatly there was no internal engine damage present. As for the cost I havn't
been in to pay the bill yet. I think that it may be about £300 or there abouts.
They had a few problems setting the timeing as it was not what VW say. This is
either the Jabba sport chip or it may have had a high lift cam fitted at some point.
I will get some pictures of the damaged parts onto this post next week which
would be a fitting end to this story. Picture of Bolt and small bottom pully chewed a
bit.
