tallpaul1977 0 Posted November 29, 2007 Anyone know the max boost pressure a K04 can run? Also how much power can you get out of a 225 1.8T with the standard K04? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 29, 2007 I don't think they like going much over 1 bar, maybe 18psi or so. Most decent tuners consider circa 280hp to be the limit of the standard engine and turbo. Quote Share this post Link to post Share on other sites
samg60 0 Posted December 3, 2007 not too sure, but have seen posting of people hitting 1.7 bar on their s3s (wouldnt recomment this if you want it to last), mine runs between 1.3 and 1.4 bar I have a boost gauge that is feeding off the inlet and I consistantly see about 22 - 23 psi flat out (its probably a few psi out although not that far), I know this is inlet pressure but it coems after the intercooler so am guessing its about correct, Vince mapped it at 297 bhp and didnt seem overly concerned I think he mentioned that it saw more on its first run but set it here for a reasonably healthly and safe Map, it was seeing 1.5 bar when I took it in. I think taking them much above what I have anyway and you will really be loosing any realy gains of the turbo as the air will be bloody hot. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted December 3, 2007 My K03S peaks at 22 PSI and holds 20 PSI up to 4500rpm before dropping to 15 PSI at 5500rpm. You can expect a couple more from a K04 for a bit longer I'd say. That's on a stage two Custom-Code map with intake and exhaust mods. 280 BHP seems to be what most modified Cupra Rs are making before people go for big-turbo upgrades. Quote Share this post Link to post Share on other sites
tallpaul1977 0 Posted December 4, 2007 samg60 what have you done to your engine? Mine is a standard setup apart from the Emerald and Forge adjustable actuator, turbo inlet pipe and turbo to intercooler pipe. Quote Share this post Link to post Share on other sites
samg60 0 Posted December 5, 2007 Hi Paul, Im afraid I bought the car as is so havent got a clue whether the engine is standard or not but I have a feeling it is, its a BAM 225 engine running DTA management with a fully wrapped manifold and downpipe blue flame exhaust, and a huge intercooler which I have no idea what its out of but really does take the whole front of the car up. The car was converted by an audi engineer and originally mapped by dubsport however the conversion had a few issues and I bought it from a forum member redlee, it transpired that they had screwed up a bit with the wiring of the coilpacks and injectors which together with Vince was rectified. Quote Share this post Link to post Share on other sites
tallpaul1977 0 Posted January 7, 2008 Same here. Mine was a ex dubsport Corrado with quite a few issues wrong with it. The Corrados off to Emerald soon for a day to be remapped, be nice to see at least 260bhp Quote Share this post Link to post Share on other sites
mistrall 0 Posted January 7, 2008 silly question (not to hijack post) is there a great diference between the ko3 and ko3s? i have the ko3s , just curious. Quote Share this post Link to post Share on other sites
Rob_B 0 Posted January 8, 2008 no such thing as a K03S, its just what people call it. if you have a late 20V engine (2002 on i think) then it runs the later K03 which produces more boost and can therefore be mapped to produce about 230bhp. think the later K03 has more blades on the impellors compared to the earlier K03. they also hold boost longer i think. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted January 8, 2008 Quite frankly, I don't believe a word of that. I'm fully prepared to be proven wrong with some evidence though. I can't seem to find a definitive answer anywhere. Quote Share this post Link to post Share on other sites
Rob_B 0 Posted January 8, 2008 Quite frankly, I don't believe a word of that. I'm fully prepared to be proven wrong with some evidence though. I can't seem to find a definitive answer anywhere. dont believe what? if you put the K03 and "K03s" together then you can see they have different numbers of blades on the impellors VW dont call the later turbo a "K03s", its a term adopted by the VW community. the only way for you to have a definitive answer to this question, you need to put the 2 turbos together. if however, you were not referring to this point, then i apologise!!! :) Quote Share this post Link to post Share on other sites
