jonny-5 0 Posted December 11, 2007 How can I uprate a standard G60 fuel pump? I have the early type with the single in-tank pump. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted December 11, 2007 You've got two pumps mate,the 1 in the tank is a small delivery pump that feeds the bigger pump underneath the car. Get hold of a second hand 2.0l corrado or golf 2 gti fuel pump/filter and plastic housing(the version fitted with mech. injection) and swap them,your intank pump will then feed the big 5Bar+ fuel pump you got off the mech injected car. Quote Share this post Link to post Share on other sites
junkie 0 Posted December 11, 2007 As far as i know its the 1.8 16v pump u need as thats what i run and yes it goes under the car just in front of the rear N/S wheel and fed from the in tank pump Quote Share this post Link to post Share on other sites
jonny-5 0 Posted December 11, 2007 Some of the early G60 have only one pump. I've defineatley only got one pump, I know what the the external ones look like as I used to have a valver. How do I wire/plumb in the KR one to work with my existing unit? Quote Share this post Link to post Share on other sites
G60_Marc 0 Posted September 25, 2009 Some of the early G60 have only one pump. I've defineatley only got one pump, I know what the the external ones look like as I used to have a valver. How do I wire/plumb in the KR one to work with my existing unit? Holy thread resurrection :grin: Im doing this next week, if i tap the external pump into the electrics of the internal pump will this be ok? would i need to uprate the fuse or relay? Cheers. Quote Share this post Link to post Share on other sites
