Rob_G60 0 Posted December 31, 2007 Hi all Had my engine mount go a few weeks back, had it replaced with a Solid BBm mount and ever since the car has rocks when u have it in gear and let of at low revs, also having a knocking every now and again on the left hand side when turning and slowing down etc any help Cheers Rob Quote Share this post Link to post Share on other sites
Andy665 0 Posted December 31, 2007 The very nature of a solid mount as opposed to an OE one is that it will transmit movement / vibration through the car to a greater extent than an OE mount which will soak up much of this. When my mounts needed changing on my previous G60 I was advised to change all mounts as fitting one solid one in conjunction to worn originals was likely to throw up issues. Quote Share this post Link to post Share on other sites
junkie 0 Posted December 31, 2007 As the front mount is solid it will show up and wear the other mounts and the front crossmember bushes more, possible left mount gone or the engine just moves naturally that way now. There is still some movement in the engine and it has to go somewhere else now the front is solid Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 31, 2007 As above - one shagged mount will put more strain on the others, also check the wiring to the lambda probe is ok (bolts to a bracket ontop of the rear engine mount) could also be the front mount brackets been ripped where it's welded... Quote Share this post Link to post Share on other sites
