vw chief
HEAD GASKET
alrite boys and gals need some help need to replace my head gasket wanted to know which is the best one for my 2.9 vr6. is it a performance one? or a standard one from german swedish,andrew pages ,euro parts? hav no idea :? :?
I just bought the gasket set from GSF, as it also has the manifold, rocker cover etc gaskets. Apparently the supplier is OEM, a German firm.
Use the MK 4 24v headgasket as this is a multilayer steel gasket and is stronger and lasts allot longer then the stock one.
I have always used OEM gaskets for the VR as they are well made and i cant be arsed to take the ead off twice. :lol:
Always OEM for the head gasket. Use p/n 021103383N as you'll gain around 0.5 on your compression ratio as well as getting the better, later gasket.
