pete86/2.0l16v 0 Posted January 9, 2008 Hi lads hope you all had a good xmas and new year. ive got a k reg 2.0 16 v and im having problems with the engine cutting out on me. The car starts fine everytime n runs gr8 for the first 3 minutes or so but after this time the engine seems to stall n keeps loosing power. i was told that it could be a problem with my idle control valve but i replaced this today and the problem still persists. ive checked all the pipe work n everything seems fine . Please Help any suggestions will be greatly appretiated. Thanx Quote Share this post Link to post Share on other sites
Blaklabel313 0 Posted January 9, 2008 i cant help you on what it might be but ive recently stripped my injection system out of my valver so if you want to borrow/try my old metering head your more than welcome. or any other parts for that matter. Quote Share this post Link to post Share on other sites
pete86/2.0l16v 0 Posted January 9, 2008 Thanks m8 ill keep that in mind im gonna strip it all down at the weekend so hopefully ill find the cause of my problem jst trying to get a head start on here lol thanx again Quote Share this post Link to post Share on other sites
pete86/2.0l16v 0 Posted February 4, 2008 alrite lads im still having trouble with my rado but ive discovered that if i remove the 2 sensors goin into the metering head then the car runs fine but wont stay on tick over! WHAT DOES THIS MEAN LOL ?? do i need a new ecu or could it be wiring or sensors even? any advice is appretiated . Thanx Peter Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 4, 2008 ... ive discovered that if i remove the 2 sensors goin into the metering head then the car runs fine but wont stay on tick over! ... It should be running in average settings for temperature etc. and ignoring sensor inputs including the Lambda if you do this. From one other 2L 16v I've seen with these symptoms I believe it was a dodgy lambda that was the problem. Quote Share this post Link to post Share on other sites
pete86/2.0l16v 0 Posted February 4, 2008 thanx m8 ill give it a go n let u no how i get on cheers for the feedback m8 Quote Share this post Link to post Share on other sites
pete86/2.0l16v 0 Posted February 7, 2008 Alrite thanks guys for your help turned out to be a dodgy ecu so my c is all up runnin great again im lovin it cheers Peter Quote Share this post Link to post Share on other sites
