flusted
Audi s2 injector flow rates??
S2 - Bosch part number 0 180 150 951 - 346cc/min @ 3bar
RS2 - Bosch part number 0 280 150 984 - 386cc/min @ 3bar
HTH
From that you can work out the diameter of the aperture of the injector nozzle if you know how long the injectors open for.
Preferable in ms, but i'll take seconds :lol:
Flusted, if you're planning to use these for your G60, then why not use this formula instead:
Fuel flow (cc per min) = (HP x K)/C
Where:
HP is maximum horsepower,
K is a constant (4.6 for normally aspirated, 5.6 for charged engines)
C is the number of engine cylinders.
You can work out the exact cc fuelling you require depending on how much power you want to run.
(Courtesy of a textbook)
