boost monkey 0 Posted February 5, 2008 Aha, cool cheers. We couldn't have done that last time as we didn't have one of those stupid thin sockets which fits down the tapered spark holes in a KR head. But will see if we can find one to take up next time. Quote Share this post Link to post Share on other sites
Zeal 0 Posted February 7, 2008 i had a starting problem with my 1.8 16v recently, after trying everything, turned out it just needed a very long pull start, it took a couple of spins round the block to get it running smoothly again. revs were all over the place at first (going down under excelleration) Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 7, 2008 Cheers zeal, will bear that in mind! So far possible problems are: no petrol (obvious) ISV shot, wiring might need looking at, weak spark - checked earths, could be ignition switch, probably a couple more things i can't remember... Anyone around stafford on saturday, drop me a pm! :lol: Quote Share this post Link to post Share on other sites
Jim 2 Posted February 7, 2008 I don't suppose there are any engine bay pictures of where all of the main earth straps should be on a valver is there? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 7, 2008 from mine? No extra pics yet. I remember wirebrushing and regreasing the following though: Ignition coil to cylinder head ribbon strap earth, battery earth just next to washer bottle, earth point next to distributor (on the corner of the head) all of them were very corroded, and probably weren't helping but the same symptoms persisted after this. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted February 8, 2008 EXTREME UPDATE ATTACK!! So, my new ISV and cold start valve came today plus the WUR i've had all along, so I'm hoping to do the following when I go back up tomorrow: Put petrol in via Mr. Jerry Can, Stick ISV on, Stick CSV on, Stick WUR on (maybe), Check wiring again - continuity tests with Multi-Meter (All - is it worth leaving that LED plugged into the ISV connector and then swapping around all the 1-pin connectors until I find one which gives a continuous 12v+ signal to the ISV connecter, as opposed to the tiny little pulse?) Swap ignition switch with Prodigal's G60 (cheers bro :thumb right: ) Check head to cam timing via TDC measurement through spark plug hole. Compression test using gunson after taking spark plugs out. If anyone can think of anything else please feel free to add it here, as I'm looking for pretty much a ticklist of stuff to do tomorrow. Want to drive it home! :D Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted February 12, 2008 (Update: It runs! See this thread for the ongoing saga: viewtopic.php?f=11&t=65658 ) This thread is so useful that I've pointed someone else at it already :D Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 14, 2008 Sorry to resurrect this bad boy, but i'm having some trubs locating a part on vagcat. Basically, one of the single-pin switches which I had sooo much fun rewiring has snapped off...but the vagcat picture is of an 8v and a lot of the locations of the switches seem different. Basically, I'm on this page: OIL PRESSURE SWITCH / THERMAL SWITCH / TEMPERATURE SENDER / SWITCH FOR REVERSING LIGHT / / 4 cylinder And I need to get the lower-left 1-pin connector, it has a red-green striped wire going to it...anyone know which part number it is on this diagram? I'm thinking it could be one of the Number 8s...? Any help appreciated! Cheers. Quote Share this post Link to post Share on other sites
Toad 0 Posted March 14, 2008 Can't get onto VAG CAT, but my etka is showing me a load of sensors with the part no. 049 919 501 Which I guess is them, I think they're all the same unit, the three water temp senders on the end of the head and the one for the oil on the back of the head. Think Goldie bought one for his golf a little while back, so he might remember the no. Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted March 14, 2008 While you're waiting to find out the part code, why not rob your spare KR for that sensor? It may even have a partcode stamped on the body. :wink: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 14, 2008 fraid not bro, spare engine is senseles in this particular area! bump for someone to tell me what the red-green is/does. Quote Share this post Link to post Share on other sites
mattkh 0 Posted March 14, 2008 bump for someone to tell me what the red-green is/does. Hi It is is used by the Control unit for the ISV. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 14, 2008 ohhhhh, so THAT's why since the pin snapped on it the car is trying to idle at 5-700rpm? Awesome, cheers Matt! Do you know which part it would be on that diagram link above? Is it one of the thermotime switches (a Number 8 part on the vagcat diagram)? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 14, 2008 Can't get onto VAG CAT, but my etka is showing me a load of sensors with the part no. 049 919 501 Which I guess is them, I think they're all the same unit, the three water temp senders on the end of the head and the one for the oil on the back of the head. Think Goldie bought one for his golf a little while back, so he might remember the no. Cheers toadie, that is exactly the right part on VagCat! Will be popping up to see Dav tomorrow then! Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 15, 2008 Ok, I've recovered from my financial Pwnage... guess how much that 1-pin thermotime switch was??? :shock: :shock: :shock: Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted March 15, 2008 Hmmm, about £30? Not that I slipped Dave a fiver to apply a -100% discount to you order, or anything... :wink: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 15, 2008 Way to blow the surprise dude. Dave wasn't even there, it was a bald guy named Gary (pwned!) and the only one in stock was at Iffley Road...major parts search! Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted March 15, 2008 :lol: Like I said, it's not like I slipped him a fiver... Did you get any discount? Gary is not Dave, if you catch my drift. Still, that's mucho dinero for a single sensor :roll: Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 15, 2008 I don't catch your drift to be honest :? and I don't think Dave properly knows me yet anyways. No I didn't get any discount, but then again I am not entitled to any discount! Plus the part was actually bought from Iffley Road. Quote Share this post Link to post Share on other sites
ProdigalSon 1 Posted March 15, 2008 Just saying Dave is a great guy and will often go out of his way to help you out, Gary less so, in my experience. :wink: Iffley and Kidlington both give 'GTi Club' discount if requested, and I don't think they've ever asked to see my CCGB card. Do you have one bro? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 15, 2008 Nope, not yet. Last time I went and looked it was a form you have to print out and then post off....which is a lot of hassle. Quote Share this post Link to post Share on other sites
