alpinewhite16v 0 Posted February 18, 2008 I need to take off the injectors in order to take off the bottom air intake manifold - how do the injectors come out and what do I need to do to ensure that everything runs smoothly? Cheers Marcus Quote Share this post Link to post Share on other sites
Jim 2 Posted February 18, 2008 I believe it's just a question of getting a good grip of the base of the injector and giving it a bloody good pull.. be careful you don't do backwards into a wall or something when it finally lets go though :) Ensure you have all new rubber seals, etc when you replace them! Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 18, 2008 There's a clip holding the injector in place, remove it then as Jim says give it a good pull. Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 18, 2008 you'll find it easier when the engine's warm and the rubber o-ring seals softer. Quote Share this post Link to post Share on other sites
nocrap 0 Posted February 18, 2008 Ensure you have all new rubber seals, etc when you replace them! This is what i hoped to do when i removed mine, the job however was harder than the actual removal. managed to do 2 but no matter how hard i tried i couldn't do the others. Quote Share this post Link to post Share on other sites
Jim 2 Posted February 18, 2008 I noticed that this place does a Fuel Injector puller suitable for 8v's but also works on 16v's.... http://www.germanautoparts.com/Volkswag ... /Fuel/95/1 Quote Share this post Link to post Share on other sites
nocrap 0 Posted February 18, 2008 good spot, looks easy enough to make one as well. Quote Share this post Link to post Share on other sites
