corraptor_evo 0 Posted February 22, 2008 Do a Syncro system suport 500HP? I allready upgraded my G60 C with a syncro system (from a '91 Passat) and I'm preparing my C for over 500 BHP from a VR6 engine base: 3.0L overbore, Garret T60-1, forged pistons(Wiseco), conrods (Panchi), rods (ARP), 440 ccm injectors, Sachs Racing Clutch stage III etc. I allready bougt a VR6 syncro gear box (CSR), but I want to know: Do this Syncro system (VR6 gearbox+VC+G60 syncro rear dif) suport 500HP? Which part is weak? Please, any answer is a real support for me! Thank you all! Quote Share this post Link to post Share on other sites
blue95 0 Posted February 22, 2008 Nope syncro maxes out at 300bhp, anything else and you will be on borrowed time. For big power consider haldex Quote Share this post Link to post Share on other sites
corraptor_evo 0 Posted February 22, 2008 I thought so! But the gearbox will resist? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 22, 2008 The 02A gearbox isn't that strong, can only take about 350whp reliabley. These guys aren't far from you and make very strong gearsets for the 02A :- http://www.sqsracing.com 800whp no problem. But the gear casing might shatter. 02M is the strongest box. I know of someone putting over 400hp through a Rallye synchro with no problem so far..... Quote Share this post Link to post Share on other sites
corraptor_evo 0 Posted March 1, 2008 Thank you very much for yor answer. I'll need more infos for sustaining my project, anyway. Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted March 5, 2008 bear in mind haldex is not compatible with 02A... Quote Share this post Link to post Share on other sites
corraptor_evo 0 Posted March 10, 2008 bear in mind haldex is not compatible with 02A... That means I need a 02M? But 02M is compatible with VR6 engine? Quote Share this post Link to post Share on other sites
