junkie
Rear ARB adjustment
I currently have the adjustable Neuspeed 25mm rear ARB, i need to adjust it to it's stiffest setting.
When i get it up onto the axle stands do i need to have it so the suspension is compressed as though it's sat on the ground or like its jacked up if that makes sense, just need to move the rose joints into the next hole on the bar?
when i had one i would adjust the bits with car jacked up anyway, then tighten them up properly with car on the ground
