n3p
Quickie - Which Goodridge?
Hi,
Getting some 280mm calipers for my 16v, was just wondering which goodridge hoses to get? Would it be G60 or 1.8? Or are they the same? Will be using G60 discs
Cheers..
I bought late G60 pipes for my early valver with 288s and they're a bit long. the later cars had a different bracket for the solid brake line which fits much better, not sure what yours would have.
Not convinced the 16v pipes fit though. I'd buy the pipes for the equivalent age g60 if i were to repeat the process...
I've got the 1991 weird hybrid 1.8 valver (i.e: 2.0L steering pump/belt set up) if that helps? But i think you're right about getting the g60 pipes
