Riley
G60 - Connectors behind center console? Who knows what t are
Does anybody know what these are for?
Theres a plastic block behind the center console, its clipped onto the floor via a metal clamp and it has about 3/4 wires plugged into it...
Anyone know what they are?
Cheers,Neil. :)
Cheers guys, its not the diag plugs as they are under the gaitor...
One of them has 12v+ when the ignition is on.
There are 3 plugs all together, and the connector block actually links the 12v to the other 2 plugs...
Just wondered really...Gauges is a good possability i reckon. :)
Neil.
Cheers,Neil. :)
Should be additional instruments as all Corrados have the wiring in the engine bay for them so it would make sense the wiring is in the rest of the car.
If you could get a pic or post up some colours of the wires I can check the wiring diagram in the manual.
So is there any wiring in those connectors for the cubby hole gauge kit that i could use in my Audi dials then?
