rado-steve
Rear Beam Question......
Just a quickie.......
Is a Corrado Rear beam same as a MK2 golf???? I know the bushes are the passive rear steer things just wondered about the beam as wanna get one to clean up/powder coat before I do my suspension etc!
Thanks
Steve
The beam is the same, not sure whether it will have all the fitting mounting points though for the ABS wiring runs..
yeah, there's a whole load of part number alternatives and the only ones the same as the 16v/G60 Corrado are the G60 mk2 golf
there is also a change from chassis no. 50 -L-035000 (round about 1991)
would be good to know if it's only minor fittings (like the ABS) that are different as that would open up a whole load of options for much later parts (in better nick) mk3's possibly.
so did the Corrado rear integral ARB change in diameter in 1991/2 then?, the 16v and G60 part no.s seem to be the same but updates after the 'L' chassis number.
