aks650
VR6 Idle control valve..?
Easy to fit, yes. You just have to disconnect the pipes (jubilees or spring clips usually) take the engine loom connector off the end and then prise it out of the rubber boot that it sits in. (And the reverse for re-fitting of course)
Expensive... new.. yes. I can't remember how much, but I was almost sure it was something silly like £90
Think it's more like £120 :? There is a seller on Ebay who sells a pattern part, which actually works perfectly for around £35...
have you got the ebay sellers name? think mines knackered the garage cleaned it an now the idle is all over the place :(
